FTP Commands: DSIZ, MFCT, MFMT, AVBL, PASS, XPWD, XMKD
Fully functional for 14 days
Explore Product Info
DSIZ FTP command
The DSIZ command is a more efficient method for clients to determine the total size of a directory and its subdirectories.
When this command is issued to the server, Serv-U determines the size of the given directory and all subdirectories and returns the value to the client. The processing load is effectively taken up by the server, allowing the client to continue to work on the FTP server.
Common responses:
Download Free TrialLearn More
MFCT FTP command
The MFCT command is used to modify a file or folder’s creation date and time information.
When a file or folder is uploaded to an FTP server , the creation date and time of the file or folder is set to the transfer date and time. Using MFCT , FTP clients can inform supporting FTP servers of the proper creation date and time to use for the file or folder. The format of the command is MFCT YYYYMMDDHHMMSS path , where:
  • YYYY – the 4-digit year
  • MM – the 2-digit month
  • DD – the 2-digit day of the month
  • HH – the hour in 24-hour format
  • MM – the minute
  • SS – the seconds
All times are represented in GMT/UTC.
Common responses:
MFMT FTP command
The MFMT command is used to modify a file or folder’s last modified date and time information. MFMT duplicates similar functionality implemented by the MDTM command. Traditionally, when a file or folder is uploaded to an FTP server, the last modified date and time of the file or folder is set to the transfer date and time. Using MFMT , FTP clients can inform supporting FTP servers of the proper last modified date and time to use for the file or folder. The format of the command is MFMT YYYMMDDHHMMSS path , where:
  • MM – the minute
  • SS – the seconds
Common responses:
AVBL FTP command
The AVBL command is useful when directory size quotas or user quotas are in place on the server. The client can issue this command and use the resulting information to determine whether or not an upload will be accepted by the server. This is particularly useful in the case of very large uploads where the limit may be reached near the end of the upload, effectively wasting the transfer time and bandwidth taken while reaching that limit.
Common responses:
PASS FTP command
A string specifying the user’s password follows this command. This command must be immediately preceded by the user name command and, for most sites, completes the user’s identification for access control. The password provided with the command is passed in clear text unless a security mechanism (e.g SSL or TLS ) has been negotiated prior to the command being issued or an alternative means of providing the password is used (e.g. MD5 S/KEY).
Common responses:
XPWD FTP command
The XPWD requests the current working directory for the connection, and is a duplicate of the PWD command. It is implemented because some firewalls assume that all FTP characters must be 4 characters in length.
Common response:
XMKD FTP command
The XMKD creates the specified directory on the server, and is a duplicate of the MKD command. It is implemented because some firewalls assume that all FTP characters must be 4 characters in length.
Common responses:
Other commands
Serv-U Managed File Transfer Server
Let's talk it over.
Contact our team. Anytime.
