232, 234, 250, 253, 257 FTP Response Codes
The requested action has been successfully completed
Fully functional for 14 days
Explore Product Info
232 FTP Response code
A 232 code may be sent in response to a USER command if the server is willing to allow the user access based on previously exchanged security data.
Example response
232 User logged in, authorized by security data exchange.
Possible command:
Download Free TrialLearn More
234 FTP Response code
A 234 code is sent in response to the AUTH command when the requested security mechanism is accepted and negotiation of the secured connection can begin.
Example response
234 AUTH command OK. Initializing SSL connection.
Possible command:
250 FTP Response code
A 250 code is sent in response to the successful completion of a file related command or user working directory related command.
Example response
250 Requested file action okay, completed.
Possible commands:
253 FTP Response code
The 253 code is sent in response to the successful completion of a change to a file’s attributes or date/time.
Example response
253 Date/time changed okay.
253 Attributes changed okay.
Possible commands:
257 FTP Response code
A 257 code is used as a successful response to the creation of a new directory from the MKD command or in response to a PWD command.
Example response
257 “PATHNAME” created.
Possible commands:
See also
Serv-U Managed File Transfer Server
Let's talk it over.
Contact our team. Anytime.
