A Best Practice Guide to Monitoring and Observability
Monitoring and Observability Guides
Introduction
When checkout slows to eight seconds, the cause might be a database lock three services deep, a container fighting for CPU on an overloaded node, DNS resolution failing for a specific ISP, or network congestion in your data center. Traditional monitoring detects these symptoms; full-stack observability connects them to their root causes across your entire infrastructure.
Modern application environments span on-premises data centers, private clouds, and public cloud services, mixing microservices with monoliths while workloads shift across bare metal, VMs, containers, and serverless platforms. Static dashboards can't track these hybrid architectures where services appear and disappear based on demand, whether you're running Kubernetes on-premises or scaling serverless functions in Amazon Web Services.
This guide covers key practices for implementing full-stack observability across your entire infrastructure. Beyond faster troubleshooting, unified observability eliminates the tool sprawl that fragments your teams and inflates costs, replacing separate application performance monitoring (APM), infrastructure monitoring, network visibility, and log management solutions with a single platform that correlates data across every layer. The result: reduced mean time to resolution, streamlined operations, and significant cost savings from tool consolidation.
Summary of Full Stack Observability Best Practices
Best Practices
Description
Implement Unified Telemetry Standards
Start with OpenTelemetry auto-instrumentation for instant coverage, then manually instrument critical business flows such as payments. You can then standardize attribute names across services so correlations occur automatically instead of requiring manual investigation.
Design Context-Aware Data Correlation
Build hierarchical correlation IDs that follow complete user journeys, making it possible to trace any issue to its exact cause. Propagate business context through headers to filter investigations by customer segment, feature flag, or a useful dimension.
Map Cross-Layer Dependencies
Use service mesh tracing to reveal actual runtime communication patterns, which rarely match your architecture diagrams. Understanding real dependencies lets you predict cascade failures and build smarter runbooks.
Build SLI-* and SLO-Driven Alerting
Define service level objectives (SLOs) based on user experience and business impact, not on infrastructure metrics. Use multi-window burn rate alerting and alert clustering to catch real problems while reducing noise.
Accelerate Root Cause Analysis with AI
Use machine learning (ML), generative AI, and now agentic AI to correlate patterns across metrics to find hidden connections, but keep in mind that AI needs time and data to learn your system. Automated workflows can gather diagnostics and recommend fixes based on past incidents.
Optimize Data Lifecycle Management
Keep data hot for debugging, warm for analysis, and cold for compliance, with retention based on business value. Strategic sampling preserves errors while reducing storage costs without losing investigative capability.
Learn from Production Failures
Automate recovery for common failures, and feed production insights back to development. Use real traffic patterns for capacity planning, and correlate feature flags with performance degradation.
Without standardized telemetry, you can't correlate front-end errors with database slowdowns happening several services deep. OpenTelemetry provides the common framework you need, connecting traces, metrics, and logs so they tell a single story instead of dozens of conflicting ones.
OpenTelemetry Adoption Strategy
Auto-instrumentation, where APM agents automatically detect your frameworks and capture standard operations, typically gets you 80% coverage. Your agents will capture HTTP endpoints, database calls, and service communications without any code changes, giving you baseline visibility for most standard monitoring needs.
You'll then need manual instrumentation for business-critical paths where auto-instrumentation can't see what matters. For example, you could use it for payment processing or search operations.
Adding a tracer should be simple. Here's a Python example of how you’d capture business context that auto-instrumentation might miss:
with tracer.start_as_current_span("payment.process") as span:
   span.set_attribute("payment.amount", order.total)
   span.set_attribute("customer.tier", customer.tier)
   span.set_attribute("risk.score", fraud_check.score)
Remember that there is performance overhead. It is minimal with modern agents, though it varies by language. Testing in staging environments that mirror production patterns should show the impact for your specific workload.
Data Type Definitions
You need to use all three telemetry types because they answer different questions: metrics indicate the current state (e.g., CPU at 85%), traces show where time gets spent across services, and logs explain why specific errors occurred. Events mark important moments, such as deployments, feature flag changes, and business milestones.
Trace context propagation works through W3C standard headers that carry trace IDs across service boundaries. Let’s say your API gateway assigns the trace ID 4bf92f35; that ID follows every downstream service call, database query, and log entry. This threading means you can connect a user's slow checkout experience directly to the specific database query.
Semantic Conventions
OpenTelemetry semantic conventions solve the naming-mismatch problem by establishing standard names that work everywhere, enabling automatic correlation. When one service uses user_id, another uses customer.id, and a third records userId, correlation is difficult. You can standardize names to look like this:
Attribute Category
Standard Names
Purpose
Service Identity
service.name
service.version
deployment.environment
Groups telemetry by service for version comparison
User Context
enduser.id
enduser.role
enduser.scope
Tracks user journeys for per-customer debugging
HTTP Details
http.method
http.route
http.status_code
Normalizes web traffic analysis
Database
db.operation
db.statement
db.sql.table
Identifies slow queries across database types
Multi-Layer Integration
Framework-specific instrumentation captures unique characteristics such as Django template rendering, Express.js route patterns, and Spring Boot Java Virtual Machine (JVM) metrics. Meanwhile, infrastructure context explains performance variations: containers competing for resources, network segments adding latency, and storage placement affecting database speed.
OpenTelemetry-compliant agents correlate application traces with infrastructure metrics automatically, revealing the relationships between slow transactions and resource constraints.
The SolarWinds Observability SaaS APM function displays ML-based health indicators with RED metrics
With standardized telemetry providing raw signals and correlation revealing their meaning, you're ready to build context-aware debugging, which lets you make better sense of the puzzle.
When users report slow checkout, you need to know where that time went. Correlation IDs break down the timeline, e.g., 200 milliseconds (ms) in the API gateway, 300 ms in inventory check, 6.5 seconds waiting for a database lock, and 1 second scattered across network hops.
Correlation ID Strategies
Start by creating a tiered hierarchy: a business transaction ID that follows the entire user journey, spawning child request IDs as transactions flow through services. This hierarchy serves dual purposes: debugging specific failures and analyzing business patterns.
When analyzing conversion drops, you can filter transactions by type and drill into child requests to find specific failure points. The patterns that emerge are useful; for example, seeing that “slow searches correlate with 40% higher cart abandonment rates,” you can configure your agents to propagate custom headers that maintain this context across technology boundaries.
Baggage and Context Propagation
Trace baggage carries the business attributes that make debugging possible, for example, customer tier for understanding resource allocation or feature flags for tracking rollout impact. Security requires careful design here: never propagate sensitive data directly, only reference IDs that services resolve independently.
High-cardinality data provides investigative power but poses storage challenges. This is because modern platforms handle millions of unique user IDs and transaction IDs using columnar storage and probabilistic structures, preserving detailed traces while efficiently aggregating metrics.
Cross-System Correlation Patterns
Correlation is powerful when you connect signals across different layers of your stack to see the full story.
Network correlation exposes hidden latency sources that masquerade as application problems. DNS resolution delays, asymmetric routing, and bandwidth saturation from backup jobs all manifest as application slowness without an apparent cause until you correlate across layers.
Infrastructure correlation links system changes to application behavior. You'll see patterns such as container scaling affecting latency, memory pressure triggering garbage-collection pauses, and storage failover slowing queries, all of which only become visible through unified timelines.
Database correlation connects queries to business impact, helping you understand which transaction triggered each query, how connection pools create queuing, and when batch jobs cause contention that affects user operations.
The PerfStack™ analysis from SolarWinds provides cross-domain correlation of data
The PerfStack™ analysis from SolarWinds provides cross-domain correlation of data (source)
Enable Shared Investigation Views
Unified correlation views eliminate finger-pointing by giving all teams the same timeline with shared context. For example, when you can show a precise situation, such as "checkout is failing for premium EU customers," it drives a different level of urgency than a generic "database slow" alert, because everyone understands the business impact.
Modern tooling can link database operations to application requests through trace context, showing not only query duration but also the actual business-transaction impact. For instance, SolarWinds® Database Performance Analyzer lets teams annotate discoveries directly on shared timelines, making debugging collaborative instead of isolated.
SolarWinds Database Performance Analyzer
Discover Runtime Dependencies
Service meshes expose surprising communication patterns. For example, you may find your checkout service talks not only to payment and inventory but also to recommendation engines, fraud detection services, and notification systems. When checkout fails during flash sales, service mesh tracing often reveals unexpected resource contention, including checkout and recommendations competing for the same database connection pool.
Example SolarWinds dashboard showing transaction times and back-end hosts
Example SolarWinds dashboard showing transaction times and back-end hosts (source)
Track Infrastructure Dependencies
Applications drift across infrastructure unpredictably, with containers restarting on different hosts and competing for resources with unknown neighbors. Performance varies wildly based on placement because resources running in different network segments add latency, whereas storage location can mean the difference between local SSD speed and slower network-attached storage.
Cloud abstractions hide critical dependencies you can't control. For instance, your managed database could rely on storage services you don't manage, your API gateways could enforce rate limits you didn't set, and your network paths could traverse availability zones in ways that add unpredictable latency.
Understand Change Cascades
Change impact ripples through dependencies in unpredictable waves, with simple changes triggering unexpected cascades. Consider this example use case where the JVM heap size was increased:
Initial Change
Direct Impact
Secondary Effect
Outcome
Increase Service Memory Limit
More aggressive JVM heap
Longer GC pauses
Upstream timeouts three services away
Update Network Policy
Additional auth hop
+50 ms per request
Connection pool exhaustion
Deploy New Service Version
Changed retry behavior
3x backend load
Database CPU saturation
Scale Pods From 3 to 10
Increased node resource contention
Network throttling
Response slowdown despite more pods
These cascades demonstrate why you must understand dependencies before making any infrastructure change.
Connect Dependencies to Revenue Impact
Technical dependency maps become actionable when you connect them to business impact. User journeys traverse dozens of services in patterns that vary by segment, location, and time of day. Mapping these to infrastructure reveals which failures actually cost money.
Consider how revenue analysis changes your priorities. When the recommendation service drives 30% of cart additions, the resulting few-second timeout becomes a quantifiable revenue loss, not only a performance metric. Customer segments experience failures differently: premium users hit different services than free-tier users, and mobile apps call different APIs than web applications. Understanding these segment-specific dependencies lets you assess impact instead of assuming every failure affects everyone equally.
Automate Dependency-Aware Responses
Dependency awareness lets you see individual incidents by showing the dependency chain, estimated impact, and team ownership together. Escalation follows both technical severity and business impact, not merely whoever's on call.
Context-aware runbooks also adapt based on dependency state instead of mindlessly executing fixes. For example, when the primary payment provider fails, the runbook checks the backup provider’s health before attempting failover. If the inventory service degrades, it might increase cache TTLs instead of restarting pods, which won't help anyway.
SolarWinds Service Maps discovers these dependencies automatically through traffic analysis and helps you correlate infrastructure changes with service impact. It calculates blast radius from observed patterns, provides dependency-aware runbooks, and eliminates the discovery phase of incident response.
span graph showing durations of component calls
A span graph showing durations of component calls
Build SLI- and SLO-Driven Alerting With Exploratory Capabilities
Alerting on every deviation creates noise, but waiting for customer complaints guarantees failure. SLI- and SLO-driven alerting measures what matters to users while preserving the ability to explore beyond those boundaries during investigations.
SLI Definition and Implementation
Indicators must reflect user experience, not system metrics; for example, password reset failures frustrate users more than newsletter API errors ever could. Response time percentiles are more telling: a p50 of 200 ms looks great until you discover that the p99 exceeds 8 seconds.
Business weighting adds context to raw metrics. For example, a failed $500 checkout hurts more than a failed product view, so track weighted success rates that correlate with revenue. When you see high request rates without conversions, you've found a problem simple availability metrics would never catch.
A multi-layer SLO composition example
Each layer contributes differently to the user experience. Front-end metrics, such as largest contentful paint, shape immediate perception, while back-end SLIs determine whether features work.
SLO-Based Alert Hierarchy
With 99.9% availability, you get a burn rate of 43 minutes of downtime per month, to catch problems before exhausting this budget. By setting and managing error budgets, you can operationalize SLOs. You do this by tracking the burn rate.
Think of burn rate as the speedometer for your error budget. At 1x, you're using your monthly budget exactly on schedule. At 60x, you're burning through it 60 times faster, exhausting a month's budget in 12 hours. These are sliding windows that only look at recent data: yesterday's outage doesn't affect today's five-minute window because it's already slid out of view.
Running multiple window checks simultaneously lets you catch different problem types:
Window
Burn rate
Action
Scenario
5 minutes
60x normal
Page immediately
Total outage
1 hour
10x normal
Page on-call
Cascading failure
6 hours
3x normal
Notify team
Memory leak
24 hours
1.4x normal
Track trend
Gradual degradation
In practice, alert only when multiple windows fire together; for example, when both the 5-minute window exceeds 60x, and the 1-hour window exceeds 10x. This combination reduces false positives while quickly catching real incidents. Start with a small set of SLOs focused on your most critical services, such as checkout, login, and search (the ones that cost money when they break). Then set realistic targets based on previous performance: if you achieved 99.5% last quarter, target 99.7% next quarter, not 99.99%.
ML-powered forecasting can use trends to predict SLO violations hours in advance, giving you time for preventive action. Alert clustering helps engineers pinpoint the important issues during an alert storm. For example, when database slowness triggers timeouts across 20 services, you get one incident with grouped symptoms instead of 20 separate alerts.
Anomaly Based Alerts Stats
SolarWinds Observability Self-Hosted anomaly-based alerts status view (source)
Explore Beyond Predefined SLOs
Predefined SLOs can't anticipate every failure mode. During investigations, you'll need to create ad hoc indicators, for example, to filter by user agent when mobile users report issues, or slice data by geography when problems seem regional.
Interactive analysis uncovers patterns you'd never think to monitor for. You might discover errors spiking exactly 24 hours post-deployment when caches expire, or checkout degrading every Tuesday during batch processing. Push beyond standard boundaries, too: when p99 looks normal, but users still complain, check p99.9. Look for partial failures that return “200 OK” instances but frustrate users anyway.
Coordinate Response Across Teams
SLO violations require coordination across teams that see the same incident differently. Unified workspaces give everyone the same data with role-specific views: DBAs see query performance, network engineers see packet flows, and product managers see revenue impact, yet they're all looking at the same incident.
Service ownership drives automated notifications without creating alert storms. For instance, payment teams get paged for payment SLOs while inventory teams receive correlation alerts, not duplicates.
When everyone knows the business impact, resource allocation happens fast. SolarWinds Observability provides comprehensive SLO tracking, with automatic error budget calculation and ML-powered violation prediction. AlertStack clustering reduces symptom noise to actionable incidents while preserving your ability to explore beyond predefined boundaries during investigations.
AI-powered analysis operates at three levels: ML correlates thousands of metrics faster than manual investigation, generative AI translates complex data into actionable insights, and emerging agentic AI takes direct action on your behalf. Each requires 30 – 90 days to learn your system's patterns before becoming reliable.
AI-Driven Root Cause Analysis
AI can help you understand metric relationships that people miss by building probabilistic models of your system's expected behavior. AI tools learn patterns such as CPU spikes correlating with GC pauses, memory pressure preceding timeouts, or DNS latency affecting specific regions. When degradation occurs, AI links it to recent changes with surprising precision. It might identify that memory leaks started when feature flags reached 50% rollout, or that database slowdowns began after new firewall rules started throttling connections.
Natural language can help summarize these findings and make them actionable:
"Checkout failures increased 300% at 14:32 due to payment timeout caused by network congestion following the 14:28 infrastructure update."
You can also prioritize using confidence scores, for example, 95% confidence in "database lock contention" warrants immediate action, while 60% confidence in "possible memory pressure" merely suggests investigation.
Root cause assist generated by AI
SolarWinds Observability Root Cause Assist with AI Five Whys summary
AI-Assisted Query Optimization
Generative AI transforms complex observability data into plain-language explanations and specific recommendations. Query Assist exemplifies this approach by analyzing slow database queries and generating optimized rewrites that deliver 10x performance improvements. Instead of cryptic execution plans, you get natural language explanations: "This query scans 2M rows because the WHERE clause prevents index usage. Try this rewrite that adds a covering index."
SolarWinds Database Performance Analyzer AI Query Assist
Context-aware diagnostics extend this approach beyond databases, replacing generic runbooks with targeted recommendations. When pattern matching shows that similar issues were resolved by JVM tuning 78% of the time, generative AI explains not only what to do, but why: "Based on 47 similar incidents, JVM heap tuning resolves this memory pressure pattern. Here's the exact configuration that worked for systems with your traffic profile."
Agentic AI for Autonomous Analytics
Agentic AI represents the next evolution: AI that not only analyzes and recommends but also executes remediation actions. While current AI provides insights and suggestions, agentic systems will directly modify configurations, restart services, scale resources, and coordinate responses across your infrastructure.
Early agentic capabilities include autonomous scaling based on predictive models, self-healing infrastructure that resolves common failures without human intervention, and intelligent load balancing that adapts to real-time performance patterns. Future agentic AI will operate your observability platform itself, creating custom dashboards, tuning alert thresholds, and optimizing data retention policies based on your team's actual usage patterns.
The progression from reactive alerts to proactive insights to autonomous action represents a fundamental shift in operations: from fighting fires to preventing them entirely.
Predictive Analytics
Autonomous investigation acts like an experienced engineer on call 24/7, saving precious time in incident response:
Stage
AI Action
Time Saved
Detection
Correlate alerts, identify scope
5 min
Collection
Gather logs/metrics/traces
15 min
Analysis
Test hypotheses
20 min
Recommend fixes with risk assessment
5 min
Predictive capabilities already forecast problems hours before SLO violations, using seasonal patterns and business events to project resource needs months ahead. These predictions become the foundation for agentic AI: instead of merely warning about capacity issues, future systems will automatically provision resources, adjust configurations, and coordinate changes across your entire stack.
SolarWinds VM capacity planning tool
SolarWinds VM capacity planning tool (source)
Establish Dynamic Baselines
All AI capabilities, from correlation to generation to autonomous action, depend on understanding what's normal for your specific environment.
Effective baselines adapt to your unique patterns. Multi-dimensional detection catches problems that single metrics miss, revealing when individually acceptable metrics collectively signal trouble. The SolarWinds AI engine delivers these capabilities through Root Cause Assist, which correlates symptoms across your stack and generates Five Whys analyses.
Full observability for a medium-sized system could generate 1 TB of data monthly, costing $500 – $1,500 in storage alone before compute costs. Without thoughtful lifecycle management, you'll either blow your budget on storage or lose critical investigative capabilities when you need them most.
Tiered Storage Strategies
Data value decreases over time, but not uniformly. Yesterday's traces help debug today's problems, last week's metrics establish baselines, last month's data supports capacity planning, and last year's records satisfy auditors.
Tiered storage aligns cost with value by moving data through hot, warm, and cold tiers based on actual access patterns:
  • Hot storage keeps your last 24 – 48 hours in memory-optimized systems for sub-second queries during active incidents
  • Warm storage balances cost and performance for the past 7 – 30 days in SSD-backed systems with queries returning in seconds
  • Cold storage archives everything else in object storage; you'll wait minutes for queries, but save 90% on storage costs
Progressive Data Reduction
Not all data ages equally. For example, error traces matter more than successful ones, and payment transactions need longer retention than health checks.
Automated aging preserves what matters while reducing volume. Keep the full resolution when the data is fresh for debugging, then progressively reduce it once you only need patterns. One-second metrics become one-minute averages after a week, then five-minute aggregates after a month. You can still see that latency spikes, but not down to the second. Full traces are thinned to representative samples, retaining all errors while sampling only successful requests. This progressive reduction typically achieves 10:1 compression without losing investigative capability.
SolarWinds Observability Database Monitoring shows historical performance and trend anomaly detection
SolarWinds Observability Database Monitoring shows historical performance and trend anomaly detection, useful for estimating data retention and tracking trends over time
Cost Optimization
Data for business-critical services needs to be retained longer than for internal tools and services; for example, revenue transaction records are retained in full, while health checks may be disposed of after a period. So not all data should be stored and accessed the same way: daily access stays hot, weekly stays warm, and monthly goes cold.
SolarWinds Observability addresses these challenges with out-of-the-box intelligent data retention policies designed to optimize storage costs while maintaining full investigative capabilities for recent data. Organizations typically achieve 60% – 80% cost reduction through automated lifecycle management.
For SolarWinds Observability SaaS, data retention policies are based on your subscription tier, with all data cleanup handled automatically by SolarWinds. Self-hosted deployments include preset retention policies you can modify; however, increasing retention will also increase your SQL database storage requirements. Platform Connect technology makes it easy to transition from self-hosted to software as a service, or to use both simultaneously, giving you flexibility as your needs evolve.
Connecting SolarWinds Observability Self-Hosted to SolarWinds Observability SaaS
Connecting SolarWinds Observability Self-Hosted to SolarWinds Observability SaaS (source)
Learn From Production Failures
Your production environment shows failures that staging can't replicate, such as race conditions from double-clicked buttons or cascading failures from real traffic distributions.
Coordinate Incident Response
Automated detection provides instant clarity. For instance, teams immediately notice that checkout has degraded by 40% for premium European customers, costing $50,000 per hour. The system calculates business impact and notifies the right teams based on expertise: database specialists for lock contention and front-end teams for rendering issues. Real-time workspaces gather relevant telemetry well before engineers open their laptops.
Automate Common Failure Recovery
It’s good practice to automate responses to common failures; for example, memory leaks could trigger rolling pod restarts at 90% utilization. Each repeated failure is a candidate for automation. If it happens twice, consider automating the recovery. Chaos engineering validates these automations through controlled experiments, such as terminating pods to confirm graceful degradation, injecting latency to verify timeouts, or simulating zone failures to test failover.
Turn Production Data into Development Priorities
As discussed earlier, production telemetry drives development priorities by revealing actual user impact, not merely synthetic test results. For example, when a new search algorithm increases latency by 30 ms, production monitoring quantifies the impact (e.g., a 2% decrease in conversion is worth $10,000 per day). This data changes vague performance concerns into concrete business decisions.
Another case is feature flag correlation, which hints at unexpected interactions between changes. A new recommendation engine might improve engagement by 15% but also increase database load by 40%, a trade-off you'd never discover in staging.
Similarly, A/B testing uncovers other surprises, like the fact that simplified checkout increases conversions but also drives more support tickets.
These production insights guide iteration and help you keep the benefits while fixing problems. Resource allocation optimization responds to actual usage patterns instead of capacity projections.
Final Thoughts
Full-stack observability enables you to understand system failures, but only when you treat it as an architectural principle instead of a monitoring upgrade. Building correlation into services, establishing semantic conventions, and automating responses create a system that shows its own behavior.
Unified observability eliminates tool sprawl, consolidating APM, infrastructure monitoring, network analysis, and log management into a single platform; reduces licensing costs; simplifies vendor management; and cuts training overhead. Teams collaborate more effectively when everyone uses the same data instead of arguing over conflicting metrics from different tools. Executive visibility improves, too: instead of pointing fingers at the technical team during outages, you can show leadership exactly what happened, which customers were affected, and what revenue was at risk.
Start with unified telemetry and correlation, as they unlock everything else. Add dependency mapping when you need to understand blast radius, and implement SLOs to focus on what matters to users. You can then layer in AI-powered analysis when manual correlation becomes overwhelming, and optimize storage before costs spiral.
Each practice builds on the previous one, creating a system that explains why problems happened. The payoff is measurable: resolution times drop from hours to minutes, alert noise decreases, and new learning opportunities emerge.
Ready to achieve visibility over your entire IT estate?
Learn More
