SolarWinds® Web Help Desk (WHD™) has always been the place where you live your workday—queue open, coffee nearby, and a constant stream of tickets competing for attention. With the latest Web Help Desk releases, that workday is changing in some important, practical ways.
This isn’t just a fresh coat of paint on the same old screens. It’s a modern, responsive experience and a rebuilt foundation designed to help you move faster, stay organized, and keep tickets moving without fighting the tool that is supposed to help you.
From “ticket system” to real work hub
The new Web Help Desk UI is built to feel like the rest of the modern tools you use every day: clean, responsive, and easy to navigate. The redesigned Approvals and Request dashboards reduce visual clutter so you can scan what matters without getting lost in dense tables and tiny links.
Instead of bouncing between disconnected screens, you can move fluidly between tickets, assets, and FAQs from a consistent navigation pane. That means less time hunting through menus and more time actually resolving issues.
Everyday example: You start the morning with a queue full of password resets, software installs, and hardware issues. With clearer dashboards and smoother navigation, it is easier to:
  • See which tickets are at risk of breaching SLAs.
  • Jump into related assets without opening a bunch of extra windows.
  • Check FAQs or request types without losing your place.
Multi‑tab workflows: Parallel work without chaos
Most help desk pros are never really working on a single ticket. You are juggling an urgent incident, a few “quick wins,” and a backlog of long‑running requests, all coming at you at once.
Multi-tab workflows in the new Web Help Desk experience are built for exactly that reality. You can open and work on multiple tickets in parallel in the application instead of managing everything in separate browser tabs.
This makes it simpler to:
  • Keep the critical incident in one tab while updating routine requests in others.
  • Switch context without losing unsaved notes.
  • Track where you are across several tickets when things get busy.
Over time, this can reduce the mental overhead of trying to remember “which ticket was I just in?” and let you focus on the work instead.
Rich text ticket communication: Better notes, better handoffs
Another everyday frustration: coming back to a ticket later and trying to decode a wall of plain text written by you or a teammate.
With rich text ticket communication, technicians can format notes, call out key steps, and paste screenshots directly into tickets. That may sound small, but it adds up quickly when you use Web Help Desk all day.
Rich text helps you:
  • Create clearer troubleshooting steps with headings and bullet points.
  • Highlight decisions or next actions so they stand out.
  • Include visual context with screenshots instead of describing every detail in text.
The result is a ticket history that is much easier to pick up midstream—whether you are resuming your own work or taking handoff from another technician.
Faster, more secure foundation (and why it matters to you)
Behind the scenes, Web Help Desk has moved to a modern, state‑of‑the‑art technology stack and hardened backend framework. That architectural work does not just benefit admins and security teams. It is also what enables the UX improvements you see now and the roadmap items that are coming next.
Because of that new foundation, SolarWinds can deliver features more quickly like:
  • Multi‑tab support for parallel ticket work.
  • Continued improvements to rich text notes and communication.
  • Next‑generation integrations with tools you already use, including Microsoft Teams, Slack, and Dameware® Remote Support.
At the same time, the strengthened framework helps address past vulnerabilities and supports a stronger security baseline, so the tool you spend your day in is better protected.
What this means for your daily workflow
If you strip away the release notes and version numbers, here’s what these changes add up to:
  • Less friction. Cleaner dashboards and navigation mean fewer clicks between where you are and what you need to do next.
  • Better focus. Multi‑tab workflows help you stay organized when you’re working several tickets at once.
  • Clearer communication. Rich text notes and inline screenshots make ticket histories easier to understand and act on.
  • A tool that can keep evolving. The modern architecture means you can expect more usability improvements going forward, not just one‑time changes.
Getting the most out of the new Web Help Desk
As your team moves to the new Web Help Desk experience, a few simple habits can help you get immediate value:
  • Use multi‑tab workflows intentionally to keep one tab for urgent work, one for quick wins, and one for “research” tickets you touch throughout the day.
  • Standardize how you use rich text notes so everyone can quickly scan a ticket and know where it stands.
  • Share feedback on what helps and what still slows you down; the new foundation is specifically designed to support ongoing improvements.
Web Help Desk is evolving from a ticket log into a more flexible, modern work hub. These changes are built to help you get through your queue with less friction and more confidence, so you can spend more time solving problems and less time wrestling with your tools.
State of ITSM Report
