Recognizing the difference between major and critical incidents is essential for IT operations, as downtime can result in significant financial losses for businesses. Gartner highlights that effective incident management can cut downtime by as much as 40%​. Major incidents disrupt business operations but are typically confined to specific systems or processes. In contrast, critical incidents pose a significant threat, causing severe operational disruptions that can affect a wide range of services and require immediate attention.
With the average global cost of a critical IT incident like data breach​, costing a record $4.45 million, it’s essential for SRE and DevOps teams to differentiate and respond appropriately. This blog will guide you through the nuances of major vs. critical incidents, offering insights to optimize your incident management strategies and minimize impacts. Stay with us to learn how to better prepare your organization for any incident.
Understanding Incident Severity – Definition and Significance
Incident severity measures how much an incident affects users and business operations. This metric is vital for incident response because it helps prioritize and allocate resources effectively. Higher severity indicates a greater impact and necessitates a faster response. For instance, a SEV 1 incident might involve a total service outage impacting all users, requiring immediate action to prevent significant business and operational disruptions.
Differentiating Incident Severity from Incident Priority
Incident severity and priority are often mistaken for one another, but they have different roles. Severity assesses the impact and extent of the problem, while priority determines the sequence in which incidents are handled. For example, a SEV 1 incident might have a high impact but be well-managed, whereas a SEV 3 incident, despite being less severe, could be prioritized differently based on other factors.
Common Incident Severity Levels: SEV 1-5
Organizations often categorize incident severity into five levels:
  • SEV 1: Critical incidents causing complete service outages or severe data breaches, requiring immediate action.
  • SEV 2: Major incidents leading to significant disruptions but not total outages, affecting many users and needing a swift response.
  • SEV 3: Moderate incidents that inconvenience users but can be managed within normal operations.
  • SEV 4: Minor incidents impacting a small number of users with minimal operational impact.
  • SEV 5: Trivial issues with negligible impact, typically resolved during routine maintenance.
Factors Influencing Incident Severity
Impact on Users
The primary factor in determining incident severity is its impact on users. The extent to which an incident affects user experience and business operations is crucial. A severe incident might result in a complete service outage, disrupting all users and halting business activities. Conversely, a less severe incident might only cause minor inconveniences to a small user segment. Recognizing this impact helps prioritize responses more effectively.
Urgency
Another crucial factor is urgency, which gauges the speed at which an incident must be resolved to avoid further damage or disruption. High-urgency incidents, such as significant security breaches or major outages, demand immediate attention to mitigate risks. In contrast, lower urgency incidents, such as minor bugs or non-critical service disruptions, can be managed within regular operational hours without severe consequences.
System Complexity
System complexity refers to the number of system components affected by an incident. Incidents involving multiple components or critical systems are typically more severe because they can lead to widespread disruption. For instance, an incident affecting a core database might be more complex and severe than one affecting a single application feature.
Business Criticality
Business criticality assesses the significance of the affected service or system to the organization’s operations. Services that are vital for daily operations, customer interactions, or revenue generation are considered highly critical. An incident impacting such services is viewed as more severe due to its potential effect on business continuity and financial health.
User Expectations
User expectations significantly influence incident severity. Different user groups have varying levels of tolerance for service disruptions. High-demand sectors, such as financial services or healthcare, have low tolerance for downtime, making incidents in these areas more severe. Understanding user expectations allows for tailored incident response strategies to meet specific needs.
Major Incidents vs. Critical Incidents
Major incidents are those that significantly impact users or business operations but do not necessarily require immediate resolution. These incidents cause substantial inconvenience and can disrupt normal activities but are generally manageable within regular response frameworks. For example, a major incident might involve a significant performance degradation affecting a large number of users but not causing a complete service outage.
Critical incidents, on the other hand, have severe consequences and demand immediate attention. These incidents are often characterized by high urgency and significant impact, necessitating rapid response to prevent extensive damage. Examples include data breaches, complete system outages, or failures in mission-critical applications that halt business operations.
Understanding these distinctions helps teams prioritize effectively, ensuring that critical issues receive the immediate attention they require while major incidents are managed efficiently to restore normal operations.
Categorizing Incident Severity
When it comes to categorizing incident severity, organizations typically use a combination of SEV levels, P levels, and custom tags. These methods provide a structured way to assess and communicate the impact and urgency of incidents.
  • SEV Levels (Severity Levels): This is a common method where incidents are categorized from SEV 1 to SEV 5, with SEV 1 being the most severe and SEV 5 being the least. SEV 1 incidents might involve total system outages, while SEV 5 incidents could be minor bugs with little impact.
  • P Levels (Priority Levels): Similar to SEV levels, P levels range from P0 to P3. P0 incidents are treated with the highest priority due to their critical impact on the business or user experience.
  • Custom Tags: Organizations often create custom tags to better fit their specific needs. These tags can include details like the affected components, impacted user segments, or specific business functions.
Using Service-Level Indicators (SLIs) and Service-Level Objectives (SLOs)
Service-Level Indicators (SLIs) and Service-Level Objectives (SLOs) are essential for evaluating incident severity.
  • Service-Level Indicators (SLIs): These metrics measure service performance, such as response time, error rate, and system throughput. SLIs offer quantifiable data to assess incident severity.
  • Service-Level Objectives (SLOs): These are the targets for SLIs. For example, an SLO might specify that 99.9% of requests should be processed within a certain response time. Deviations from SLOs signal potential issues that may need to be classified as severe incidents.
Using SLIs and SLOs helps teams objectively determine how critical an incident is, ensuring that the response is proportional to the impact.
Customizing Severity Levels for Specific Organizations
Customizing severity levels is crucial as each organization has unique needs and operational contexts. Here’s how to approach it: –
  • Assess Business Impact: Evaluate how different services and systems affect business operations.
  • Team Collaboration: Work with various teams, including product, engineering, and operations, to develop a comprehensive incident severity framework. This ensures all potential impacts are considered.
  • Incident Priority Matrix: Use a priority matrix to align severity with priority. For instance, a high-severity incident affecting a critical business function might be prioritized higher than a similar severity incident affecting a less critical function.
Example Matrix:
Priority Severity 1 Severity 2 Severity 3
High P0 P1 P2
Medium P1 P2 P3
Low P2 P3 P3
This matrix helps in ensuring that the most critical and urgent issues are addressed first, maintaining business continuity and user satisfaction.
Implementing Incident Severity Classification
Effective incident management relies on a well-defined system for  classifying severity level. Platforms like SolarWinds Incident Response offer customizable severity levels, enabling teams to prioritize and address incidents based on their impact and urgency. This structured method ensures that the most critical issues are resolved quickly, reducing downtime and enhancing overall service reliability.
Setting Up and Using Custom Tags and Routing Rules in SolarWinds Incident Response
To optimize incident management, SolarWinds Incident Response offers tools for setting up custom tags and routing rules. Here’s how to leverage these features:
Custom Tags:
  1. Creating Tags:
    • Navigate to the settings in SolarWinds Incident Response to create custom tags that reflect your organization’s specific needs. Tags can be based on various criteria such as “Database Issue,” “Performance Degradation,” or “Security Breach.”
  2. Applying Tags:
    • Apply relevant tags to incidents manually or automate the tagging process based on incident attributes. This ensures incidents are categorized accurately, facilitating quick identification and resolution.
Routing Rules:
  1. Setting Up Rules:
    • Define routing rules that align with your incident management strategy. For example, route incidents tagged as “Critical” directly to the on-call SRE team to ensure immediate attention.
  2. Automation:
    • Automate the escalation process to ensure incidents are addressed promptly. If an incident is not acknowledged within a certain timeframe, it automatically escalates to the next level of support. This prevents critical incidents from being overlooked.
  • Seamlessly integrate On-Call Management, Incident Response and SRE Workflows for efficient operations.
  • Automate Incident Response, minimize downtime and enhance your tech teams’ productivity with our Unified Platform.
  • Manage incidents anytime, anywhere with our native iOS and Android mobile apps.
Benefits of Implementing Incident Severity Classification
Implementing a structured incident severity classification system in SolarWinds Incident Response provides several key benefits: –
  • Reduced Mean Time to Repair (MTTR): Accurate incident classification allows teams to prioritize and address the most critical issues first, reducing the overall resolution time. This results in less downtime and faster service restoration.
  • Improved Incident Response: Custom tags and routing rules make incident response more organized and efficient. Teams can quickly determine incident severity and take appropriate actions without delay, enhancing overall response effectiveness.
  • Enhanced System Reliability: A robust classification system helps identify recurring issues and potential system vulnerabilities. Proactively addressing these leads to improved system reliability and fewer incidents over time.
  • Data-Driven Insights: Using Service-Level Indicators (SLIs) and Service-Level Objectives (SLOs), SolarWinds Incident Response offers valuable insights into incident trends and performance. These insights help refine incident management strategies, ensuring continuous improvement in service quality.
Wrapping Up..
Classifying incident severity is crucial for effective incident management. It helps prioritize responses, allocate resources efficiently, and minimize downtime. By understanding the impact and urgency of incidents, teams can respond swiftly and appropriately, ensuring minimal disruption to users and business operations.
Differentiating between major and critical incidents is crucial for prioritizing responses. Major incidents significantly impact users or business operations but may not require immediate action. Critical incidents, however, have severe consequences and need urgent attention. Recognizing these differences ensures that the most critical issues are addressed first, maintaining system stability and reliability.
Implement incident severity classification in your organization to enhance incident response, reduce MTTR and improve system reliability with SolarWinds Incident Response. Start today and see the positive impact on your operational efficiency and user satisfaction.
Read More on Severity Level Classification
You may also like
