Find the Right Network Monitoring Solution for You
Determine whether SolarWinds ipMonitor or Network Performance Monitor is the best fit for your environment.
ipMonitor
Network Performance
Monitor
Environment Size
Optimized for small to medium environments
Highly scalable for the most robust environments
Visibility
Essential status and performance information
Deep visibility into complex devices
Cross IT Stack Integration
Focused on network devices, servers, and applications
Full IT stack visibility—from storage to application
Troubleshooting Capabilities
Simple, focused functionality
Deep analysis capabilities across components
Deployment
Easy and self-contained
Highly flexible and customizable
ipMonitor® is quick, affordable, and agentless monitoring software for your network, servers, and applications. ipMonitor delivers out-of-the-box visibility into essential availability and performance metrics for your critical IT environment, and includes a built-in database and web server, so you don’t need to install anything but ipMonitor. It’s easy to set up and requires minimal bandwidth or processing cycles over time—perfect for small to medium environments.
Network Performance Monitor (NPM) is a powerful network monitoring software that enables you to quickly detect, diagnose, and resolve network performance problems and outages. NPM delivers comprehensive network fault monitoring and performance management that scales and expands with your network monitoring needs. NPM is built on the Orion® Platform, which allows users to extend beyond networks to monitor, visualize, and analyze the performance of applications, systems, and databases on-premises, in a hybrid environment, or in the cloud.
Contact our team. Anytime. Call +1-866-530-8100 or email sales@solarwinds.com
{{STATIC CONTENT}}
{{CAPTION_TITLE}}
{{CAPTION_CONTENT}}
{{TITLE}}
