Welcome! Use the login menu to access:
Customer Portal
Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
Application & Server Management »
Server, Application, & OS Monitoring
Web Application Monitoring
Patch Manager
security & information event management »
Log Collection & Real Time Event Correlation
network management »
network management
Performance Monitoring, Alerting, & Reporting
Configuration & Compliance Management
Bandwidth Monitoring
IP Address Space Management
WAN & VOIP Monitoring
Switch Port Monitoring & Mapping
Network Diagonstic Tools
Network Mapping
virtualization management »
VMware Performance Monitoring, Capacity Planning, & More
storage management »
storage management
SAN Performance Monitoring, Capacity Planning, & More
Power Ups
Solve IT Issues, Anytime, Anywhere
SOLARWINDS COMMUNITY SITE »
BLOGS
SOCIAL NETWORKS
COMMUNICATION
READY TO BUY?
READY TO TRY?
RENEW MAINTENANCE
Resources & Education
DOCUMENTATION »
DOCUMENTATION
KNOWLEDGE BASE »
KNOWLEDGE BASE
IT MANAGEMENT GLOSSARY »
SOLARWINDS COMMUNITY (THWACK) »
EDUCATION
RESOURCES CENTER »
RESOURCES CENTER
SOLARWINDS CERTIFIED PROFESSIONALS »
Maintenance Renewals
Product Support »
Product Support
XP Virtual Machine, also known as Windows® XP mode, refers to an instance of Windows XP running on later versions of Windows operating systems such as Windows 7. The use of an XP Virtual Machine allows users to upgrade their hardware to the current Windows operating system while still using the familiar Windows XP OS. An XP Virtual Machine can run legacy Windows XP applications that might be incompatible with new operating systems.
VM Console
What do you do when a virtual machine is running amuck—or not running at all—and you just want to restart it without slogging through vCenter™ or vSphere™? With our free VM Console you can bounce that blue-screened troublemaker, track up/down status, take snapshots of all your VMs, and more!
Download Now »
VM Monitor
Track virtualization health at-a-glance with X-ray vision into your ESX Servers! Our free VM Monitor continuously monitors a VMware ESX Server and its virtual machines and delivers detailed virtual machine health statistics including VM name, guest OS, and VM state, as well as processor, memory, and network usage.
Virtualization Manager
Virtualization Manager makes it easy to manage all the aspects of your virtual infrastructure by providing the tools to control VM sprawl, eliminate bottlenecks, optimize performance, track configuration changes, manage capacity, and track and showback departmental and business unit usage and costs. Learn More »
