• Welcome! Use the login menu to access:
    • Customer Portal
      Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
    • Community
      After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
    • Partner Portal
      SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
SolarWinds IT Management Glossary
Back to Index »
What is a Virtual Machine
A virtual machine (VM) is a software implementation of a computer that runs programs like a physical machine via software emulation or hardware virtualization. A virtual machine acts like a real machine, but the software executed on it is separate from the underlying hardware resources. A virtual machine can be either a system virtual machine that provides a complete system platform to support the execution of a complete operating system (OS) or a process virtual machine that’s designed to run a single program.
SolarWinds FREE Tools Related to Virtual Machine
VM Console
What do you do when a virtual machine is running amuck—or not running at all—and you just want to restart it without slogging through vCenter™ or vSphere™? With our free VM Console you can bounce that blue-screened troublemaker, track up/down status, take snapshots of all your VMs, and more!
Download Now »
VM Monitor
Track virtualization health at-a-glance with X-ray vision into your ESX Servers! Our free VM Monitor continuously monitors a VMware ESX Server and its virtual machines and delivers detailed virtual machine health statistics including VM name, guest OS, and VM state, as well as processor, memory, and network usage.
Download Now »
SolarWinds Products Related to Virtual Machine
Hyper9
Hyper9 Virtualization Manager makes it easy to manage all the aspects of your virtual infrastructure by providing the tools to control VM sprawl, eliminate bottlenecks, optimize performance, track configuration changes, manage capacity, and track and showback departmental and business unit usage and costs. Learn More »
Backup Profiler
Backup Profiler delivers a consolidated, real-time view of the status of all of the backups in your enterprise. With Backup Profiler, you can plan for growth, ensure backup operations are compliant with regulations and corporate standards, and prevent failed backups and data loss. Learn More »
