• Welcome! Use the login menu to access:
    • Customer Portal
      Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
    • Community
      After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
    • Partner Portal
      SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
SolarWinds IT Management Glossary
Back to Index »
What is Thin Provisioning
Thin Provisioning is the technique used to optimize the utilization of storage in a virtualized environment. Thin Provisioning accomplishes this task by over-subscribing physical storage resources based on the expectation that not all storage allocated to a given VM will be consumed by that VM. Thin Provisioning can be done at both the hypervisor layer or within the array itself; however, it should not be done in both places. While thin provisioning allows you to over-subscribe physical storage, if you do not adequately plan your physical storage capacity, it can lead to disastrous results. In the best case, thin provisioned VMs that run out of physical storage will be suspended. In the worst case, the VM will crash and data may be lost. Tools such as SolarWinds Storage Manager, Powered by Profiler allow you to report on thin provisioning whether it is done within the array or within the VMware hypervisor.
SolarWinds FREE Tools Related to Thin Provisioning
VM Console
What do you do when a virtual machine is running amuck—or not running at all—and you just want to restart it without slogging through vCenter™ or vSphere™? With our free VM Console you can bounce that blue-screened troublemaker, track up/down status, take snapshots of all your VMs, and more!
Download Now »
SAN Monitor
Quickly and easily monitor EMC®, Dell®, IBM®, and Sun® StorageTek™ storage arrays! Our free SAN Monitor delivers the real-time visibility you need to stay steps ahead of infrastructure evils that threaten to slow storage performance.
Download Now »
VM Monitor
Track virtualization health at-a-glance with X-ray vision into your ESX Servers! Our free VM Monitor continuously monitors a VMware ESX Server and its virtual machines and delivers detailed virtual machine health statistics including VM name, guest OS, and VM state, as well as processor, memory, and network usage.
Download Now »
SolarWinds Products Related to Thin Provisioning
Storage Manager
Storage Manager makes it easy to manage the performance and growth of your multi-vendor storage environment. With end-to-end mapping of your physical and virtual infrastructure, Storage Manager delivers the comprehensive view into storage health that you need to troubleshoot problems quickly. Learn More »
Virtualization Manager
Virtualization Manager makes it easy to manage all the aspects of your virtual infrastructure by providing the tools to control VM sprawl, eliminate bottlenecks, optimize performance, track configuration changes, manage capacity, and track and showback departmental and business unit usage and costs. Learn More »
