• Welcome! Use the login menu to access:
    • Customer Portal
      Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
    • Community
      After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
    • Partner Portal
      SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
SolarWinds IT Management Glossary
Back to Index »
What is System Availability
System availability monitoring requires administrators to track performance on numerous systems throughout the network. System availability management can minimize end-user system failure. System availability tools deliver real-time data about processor and memory usage, disk usage and availability, as well as other key metrics that can point to potential problems before they arise.
SolarWinds FREE Tools Related to System Availability
Network Device Monitor
Monitor the real-time performance and health of a single device on your network with a cool desktop dashboard. Get started immediately with "out-of-the-box" monitors for Juniper® devices, Cisco ASA appliances, HP Procurve equipment, Cisco switches, and more.
Download Now »
SolarWinds Products Related to System Availability
Orion NPM v9.5.1 - Evaluation
Orion Network Performance Monitor (NPM) enables you to quickly detect, diagnose, and resolve network performance problems and outages—before you start getting calls asking if the network is down. And Orion NPM is the easiest product of its kind to deploy, use, and maintain. That means you can spend your time actually managing your network, not supporting your network management software. Learn More »
