• Welcome! Use the login menu to access:
    • Customer Portal
      Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
    • Community
      After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
    • Partner Portal
      SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
SolarWinds IT Management Glossary
Back to Index »
What is Network Fault Management
Network Fault Management refers to the processes and technologies that network administrators use to avoid the occurrence of, and recover from instances of, network failures. Network Fault Management can be strategic or tactical. Network Fault Management tools typically include network discovery utilities and network configuration management tools.
SolarWinds FREE Tools Related to Network Fault Management
Network Device Monitor
Monitor the real-time performance and health of a single device on your network with a cool desktop dashboard. Get started immediately with "out-of-the-box" monitors for Juniper® devices, Cisco ASA appliances, HP Procurve equipment, Cisco switches, and more.
Download Now »
SolarWinds Products Related to Network Fault Management
Orion NPM v9.5.1 - Evaluation
Orion Network Performance Monitor (NPM) enables you to quickly detect, diagnose, and resolve network performance problems and outages—before you start getting calls asking if the network is down. And Orion NPM is the easiest product of its kind to deploy, use, and maintain. That means you can spend your time actually managing your network, not supporting your network management software. Learn More »
