• Welcome! Use the login menu to access:
    • Customer Portal
      Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
    • Community
      After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
    • Partner Portal
      SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
SolarWinds IT Management Glossary
Back to Index »
What is Monitoring and Diagnostics
Monitoring and diagnostics are tasks involved in effectively managing both the virtual and physical resources of any IT environment. Monitoring and diagnostics, though similar in intent, involve slightly different tasks. Monitoring involves detecting and tracking changes to a virtual environment, including its configuration, health, and overall performance. In a virtualized environment, administrators must monitor both virtual and physical resources, so the task can be complex at times. If a problem occurs, the diagnostics process must take into account the correlation between the virtual resources and the physical ones on which they rely.
SolarWinds FREE Tools Related to Monitoring and Diagnostics
SAN Monitor
Quickly and easily monitor EMC®, Dell®, IBM®, and Sun® StorageTek™ storage arrays! Our free SAN Monitor delivers the real-time visibility you need to stay steps ahead of infrastructure evils that threaten to slow storage performance.
Download Now »
VM Monitor
Track virtualization health at-a-glance with X-ray vision into your ESX Servers! Our free VM Monitor continuously monitors a VMware ESX Server and its virtual machines and delivers detailed virtual machine health statistics including VM name, guest OS, and VM state, as well as processor, memory, and network usage.
Download Now »
SolarWinds Products Related to Monitoring and Diagnostics
Backup Profiler
Backup Profiler delivers a consolidated, real-time view of the status of all of the backups in your enterprise. With Backup Profiler, you can plan for growth, ensure backup operations are compliant with regulations and corporate standards, and prevent failed backups and data loss. Learn More »
