• Welcome! Use the login menu to access:
    • Customer Portal
      Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
    • Community
      After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
    • Partner Portal
      SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
SolarWinds IT Management Glossary
Back to Index »
What is IT Systems Management
IT systems management tools bring automation and aggregation to the process of monitoring and managing distributed IT resources. IT systems management tools gather data, filtering out unimportant background data, and present the key performance indicators in snapshot views. IT systems management tools help administrators reduce the complexity of managing their infrastructure.
SolarWinds FREE Tools Related to IT Systems Management
VM Console
What do you do when a virtual machine is running amuck—or not running at all—and you just want to restart it without slogging through vCenter™ or vSphere™? With our free VM Console you can bounce that blue-screened troublemaker, track up/down status, take snapshots of all your VMs, and more!
Download Now »
SAN Monitor
Quickly and easily monitor EMC®, Dell®, IBM®, and Sun® StorageTek™ storage arrays! Our free SAN Monitor delivers the real-time visibility you need to stay steps ahead of infrastructure evils that threaten to slow storage performance.
Download Now »
VM Monitor
Track virtualization health at-a-glance with X-ray vision into your ESX Servers! Our free VM Monitor continuously monitors a VMware ESX Server and its virtual machines and delivers detailed virtual machine health statistics including VM name, guest OS, and VM state, as well as processor, memory, and network usage.
Download Now »
SolarWinds Products Related to IT Systems Management
Orion NPM v9.5.1 - Evaluation
Orion Network Performance Monitor (NPM) enables you to quickly detect, diagnose, and resolve network performance problems and outages—before you start getting calls asking if the network is down. And Orion NPM is the easiest product of its kind to deploy, use, and maintain. That means you can spend your time actually managing your network, not supporting your network management software. Learn More »
Server & Application Monitor
SolarWinds Server & Application Monitor delivers powerful application and server management capabilities at an affordable price. With automatic application discovery, you'll be monitoring, alerting, and reporting in less than an hour! Learn More »
