• Welcome! Use the login menu to access:
    • Customer Portal
      Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
    • Community
      After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
    • Partner Portal
      SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
SolarWinds IT Management Glossary
Back to Index »
What is IT Infrastructure Management
IT infrastructure management tools enable a centralizing view of server monitoring and management. IT Infrastructure Management requires implementation of specialized software for real-time monitoring and management of networked systems. IT infrastructure management tools are designed to identify and mitigate sources of risk so as to increase availability of networked servers.
SolarWinds Products Related to IT Infrastructure Management
Orion NPM v9.5.1 - Evaluation
Orion Network Performance Monitor (NPM) enables you to quickly detect, diagnose, and resolve network performance problems and outages—before you start getting calls asking if the network is down. And Orion NPM is the easiest product of its kind to deploy, use, and maintain. That means you can spend your time actually managing your network, not supporting your network management software. Learn More »
Server & Application Monitor
SolarWinds Server & Application Monitor delivers powerful application and server management capabilities at an affordable price. With automatic application discovery, you'll be monitoring, alerting, and reporting in less than an hour! Learn More »
Hyper9
Hyper9 Virtualization Manager makes it easy to manage all the aspects of your virtual infrastructure by providing the tools to control VM sprawl, eliminate bottlenecks, optimize performance, track configuration changes, manage capacity, and track and showback departmental and business unit usage and costs. Learn More »
Storage Profiler
Storage Profiler makes it easy to manage the performance and growth of your multi-vendor storage environment. With end-to-end mapping of your physical and virtual infrastructure, Storage Profiler delivers the comprehensive view into storage health that you need to troubleshoot problems quickly. Learn More »
