• Welcome! Use the login menu to access:
    • Customer Portal
      Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
    • Community
      After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
    • Partner Portal
      SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
SolarWinds IT Management Glossary
Back to Index »
What is a Fibre Channel
A Fibre Channel (FC) is a serial I/O interconnection capable of supporting multiple protocols, including access to open system storage (FCP), to mainframe storage (FICON), and to networking (TCP/IP). Fibre Channel supports point-to-point, arbitrated loop, and switched fabric topologies over a variety of copper and optical links and running at speeds from 1 Gb/s to 10 Gb/s.
SolarWinds FREE Tools Related to Fibre Channel
SAN Monitor
Quickly and easily monitor EMC®, Dell®, IBM®, and Sun® StorageTek™ storage arrays! Our free SAN Monitor delivers the real-time visibility you need to stay steps ahead of infrastructure evils that threaten to slow storage performance.
Download Now »
SolarWinds Products Related to Fibre Channel
Storage Manager
Storage Manager makes it easy to manage the performance and growth of your multi-vendor storage environment. With end-to-end mapping of your physical and virtual infrastructure, Storage Manager delivers the comprehensive view into storage health that you need to troubleshoot problems quickly. Learn More »
Backup Profiler
Backup Profiler delivers a consolidated, real-time view of the status of all of the backups in your enterprise. With Backup Profiler, you can plan for growth, ensure backup operations are compliant with regulations and corporate standards, and prevent failed backups and data loss. Learn More »
