Welcome! Use the login menu to access:
Customer Portal
Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
Application & Server Management »
Server, Application, & OS Monitoring
Web Application Monitoring
Patch Manager
security & information event management »
Log Collection & Real Time Event Correlation
network management »
network management
Performance Monitoring, Alerting, & Reporting
Configuration & Compliance Management
Bandwidth Monitoring
IP Address Space Management
WAN & VOIP Monitoring
Switch Port Monitoring & Mapping
Network Diagonstic Tools
Network Mapping
virtualization management »
VMware Performance Monitoring, Capacity Planning, & More
storage management »
storage management
SAN Performance Monitoring, Capacity Planning, & More
Power Ups
Solve IT Issues, Anytime, Anywhere
SOLARWINDS COMMUNITY SITE »
BLOGS
SOCIAL NETWORKS
COMMUNICATION
READY TO BUY?
READY TO TRY?
RENEW MAINTENANCE
Resources & Education
DOCUMENTATION »
DOCUMENTATION
KNOWLEDGE BASE »
KNOWLEDGE BASE
IT MANAGEMENT GLOSSARY »
SOLARWINDS COMMUNITY (THWACK) »
EDUCATION
RESOURCES CENTER »
RESOURCES CENTER
SOLARWINDS CERTIFIED PROFESSIONALS »
Maintenance Renewals
Product Support »
Product Support
Fibre Channel Switched Fabric (FC-SW) is a type of switched fabric network topology in which network nodes connect with each other via one or more fibre channel network switches— in particular, via cross bar switches, where it gets the name. Fibre Channel Switched Fabric topology allows the connection of up to 16 million devices, the theoretical maximum. Of the three FC topologies, Fibre Channel Switched Fabric offers the best scalability; it is also requires Fibre Channel switches.
SAN Monitor
Quickly and easily monitor EMC®, Dell®, IBM®, and Sun® StorageTek™ storage arrays! Our free SAN Monitor delivers the real-time visibility you need to stay steps ahead of infrastructure evils that threaten to slow storage performance.
Download Now »
Storage Manager
Storage Manager makes it easy to manage the performance and growth of your multi-vendor storage environment. With end-to-end mapping of your physical and virtual infrastructure, Storage Manager delivers the comprehensive view into storage health that you need to troubleshoot problems quickly. Learn More »
Backup Profiler
Backup Profiler delivers a consolidated, real-time view of the status of all of the backups in your enterprise. With Backup Profiler, you can plan for growth, ensure backup operations are compliant with regulations and corporate standards, and prevent failed backups and data loss. Learn More »
