Welcome! Use the login menu to access:
Customer Portal
Solarwinds customers can download purchased software, renew maintenance, & more in our updated Customer Portal.
Community
After logging in, community members can rate & review SolarWinds software & participate in forums on thwack.com.
Partner Portal
SolarWinds channel partners will find all the resources they need in the Partner Portal, including exclusive partner tools.
Application & Server Management »
Server, Application, & OS Monitoring
Web Application Monitoring
Patch Manager
security & information event management »
Log Collection & Real Time Event Correlation
network management »
network management
Performance Monitoring, Alerting, & Reporting
Configuration & Compliance Management
Bandwidth Monitoring
IP Address Space Management
WAN & VOIP Monitoring
Switch Port Monitoring & Mapping
Network Diagonstic Tools
Network Mapping
virtualization management »
VMware Performance Monitoring, Capacity Planning, & More
storage management »
storage management
SAN Performance Monitoring, Capacity Planning, & More
Power Ups
Solve IT Issues, Anytime, Anywhere
SOLARWINDS COMMUNITY SITE »
BLOGS
SOCIAL NETWORKS
COMMUNICATION
READY TO BUY?
READY TO TRY?
RENEW MAINTENANCE
Resources & Education
DOCUMENTATION »
DOCUMENTATION
KNOWLEDGE BASE »
KNOWLEDGE BASE
IT MANAGEMENT GLOSSARY »
SOLARWINDS COMMUNITY (THWACK) »
EDUCATION
RESOURCES CENTER »
RESOURCES CENTER
SOLARWINDS CERTIFIED PROFESSIONALS »
Maintenance Renewals
Product Support »
Product Support
Memory Usage Monitor is a utility that shows how much of a machine’s physical and virtual memory is in use at a given point in time. A Memory Usage Monitor may also record usage over time, noting spikes in usage which can help an administrator diagnose system errors. A Memory Usage Monitor can be useful in identifying cases where systems have been over-provisioned.
Network Device Monitor
Monitor the real-time performance and health of a single device on your network with a cool desktop dashboard. Get started immediately with "out-of-the-box" monitors for Juniper® devices, Cisco ASA appliances, HP Procurve equipment, Cisco switches, and more.
Download Now »
Orion NPM v9.5.1 - Evaluation
Orion Network Performance Monitor (NPM) enables you to quickly detect, diagnose, and resolve network performance problems and outages—before you start getting calls asking if the network is down. And Orion NPM is the easiest product of its kind to deploy, use, and maintain. That means you can spend your time actually managing your network, not supporting your network management software. Learn More »
Engineer’s Toolset v10 - Evaluation
Network troubleshooting is easy when you have the right network tools! Engineer’s Toolset delivers an advanced collection of must-have monitoring, discovery, diagnostic, and Cisco tools. Discover why thousands of network engineers rely on Engineer’s Toolset! Learn More »
