CPU Load Monitor
with Engineers Toolset
CPU Load Monitor: Tool Detail
  • Monitor and graph the load on multiple Cisco® routers concurrently
  • Set warning and alarm thresholds for each device
  • New! Supports IPv6 and SNMP v3 (includes AES 256)
Today's business networks are subject to exposure to a vast number of worms and viruses. Often, an infection will cause increased traffic load and increased CPU load on your routers. SolarWinds Advanced CPU Load allows you to monitor and graph the load on multiple Cisco routers concurrently so that you can stay ahead of problems.
Warning and alarm thresholds can be independently set for each device. If the load on a Cisco router reaches the user-defined threshold for a warning, the load bar turns yellow. If a critical level is reached, the bar turns red. SolarWinds Advanced CPU Load also records the peak load level and when it happened.
{{STATIC CONTENT}}
{{CAPTION_TITLE}}
{{CAPTION_CONTENT}}
{{TITLE}}
